NI TestStand
SMH Flashrunner V19 to V17
Hello. I would like to have this sequence converted from TestStand 19.0.0.170 to TestStand 17.0.0.184.
(2,817 Views)
You posted in the Version Conversion board for LabVIEW.  (See note 2 in the Rules at the top of the Version Conversion board).
Requests to convert versions of other NI software is very uncommon, thus there are no boards dedicated to other software.
I've moved your message to the teststand board where someone who browses that forum would be able to help you.
(2,761 Views)
Thank you... and sorry, I probably was lost in thought!
(2,713 Views)
Accepted by dspinello
Here you go. Hope this helps
-Trent
https://www.linkedin.com/in/trentweaver
(2,689 Views)
