NI TestStand
SSP for runtime
This question has come from management and I have not found a person to answer yet. It costs $95 to upgrade the runtime license for a TestStand workstation. We have the SSP for Pro Test Edition of LabVIEW, so I would assume that we will get the 3.5 version of TestStand as part of it. Does the SSP cover our runtimes? After running the upgrade advisor for TestStand base deployment and entering qty (10), as a plausible population for us, the base deployment upgrade cost is still $95. Am I correct in assuming that the upgrade case for deployment is "Upgrade One, Upgrade them all"? and that NI will retain this policy in the future?
(4,070 Views)
Hi Odd Modem,
    Unfortunately, SSP does not cover the upgrade of Deployment Licenses. As you mentioned, to upgrade your base deployment license, it will be $95 per license. The upgrade advisor will initially give you a price of $95, but the last page of the advisor should give you the grand total, which for your 10 deployment licenses will be $950.
Hope this answers your question Odd Modem, let us know if we can answer anything else for you.
Have a good one!
Dan Weiland
Dan Weiland
(4,050 Views)
Yes actually, the sales page for the base deployment says this:
900850D-01 TestStand Base Deployment Engine License ver. 3.x $500
Where 3.x obviously means that it works with any 'three' version of TestStand. When I use upgrade advisor to go from 3.0 to 3.1 it still wants to charge me $95. I don't understand, 3.x means that it is good for 3.0, 3.1 and 3.5 (if it ever comes out.) Why doesn't upgrade advisor say $0 to go from 3.0 to 3.1?
(4,031 Views)
I agree that the website wording is slightly confusing, however the idea is to indicate that these licenses are backwards compatible for all the 3.x versions, not forwards compatible.
Since we only have licenses for the most recent version of TestStand available at a given time, this backwards compatibility allows somebody with a 3.0 sequence they wish to deploy to purchase a license that will work, even though only 3.1 deployment licenses are available. However a 3.0 deployment license needs to be upgraded before a 3.1 sequence can be deployed under that license.
I apologize for the confusion, I hope this answers your questions.
Dan Weiland
Dan Weiland
(4,012 Views)
yes, Thank You.
(3,997 Views)
