NI TestStand
Save 'Find Results' to a file?
When editing in CVI, I often find it useful to copy the contents of 'Find Results' into an edit window so I can edit/parse/filter/sort the information.  I would like to be able to do the same thing in the TestStand Sequence Editor.  Is a temporary file generated when TestStand Find Results are displayed?  If so, where?  If not, is there some way to send the results to a text file?  Thanks for any help.
(3,379 Views)
Hello JoeN,
Unfortunately there are no temporary files generated when TestStand displays those results. Also, there are no API calls that can be made to capture this data. There is some built in sorting functionality in the Find Results window and it is nice to have each search result linked to the sequence, so for that reason this feature was probably not considered. If you want to can make a product suggestion here.
Jacob R. | Applications Engineer | National Instruments
(3,353 Views)
Jacob,
I went to the TestStand Idea page as you suggested.  When I click on the New Idea button, I get "Internet Explorer cannot display the webpage".  Might be due to our firewall.  Any suggestion?  (I tried closing & reopening IE.)
(3,333 Views)
Accepted by topic author JoeN
Hello JoeN,
I think the link I provided you was wrong.
Try this link.
(3,323 Views)
