NI TestStand
Save a file using .Net Assemblly ?
there are 100s of Assemblies in .Net , is there a assembly function to save a file  without opening the file-dialogue box?
Which Assembly to use ?
I want to avoid using a VI to do the same thing.
Best,
Akshay
Message 1 of 8
(2,253 Views)
Hi aparab,
.NET isn't my thing but I think this should help?
Use Existing Object(NationalInstruments.TestStand.Interop.API.Engine).GetSequenceFileEx(System.String, Int32, NationalInstruments.TestStand.Interop.API.TypeConflictHandlerTypes).Save(System.String)
Regards
Steve
Message 2 of 8
(2,252 Views)
Thanks Steve,
well I donot explicitly wantto save the Sequnce File but a Result file, which can be a txt or XML.
& the Save member Function is not present in this class.
May be I am looking for a different class/member.
Best
Akshay
Message 3 of 8
(2,238 Views)
You can configure TestStand to save Results files in a place of your choosing through the Configure->Results Processing menu.  Are you looking to implement that through .NET?
Message 4 of 8
(2,234 Views)
Hello Steve,
Yes, but I am not allowed to change those adapter settings because we have a standard  framework.
Hence I am trying to implement it in .Net.  .NET is elegant and powerfull.
For the worst case scenaio, I can always implement it with labview.
Best,
Akshay
Message 5 of 8
(2,229 Views)
I also tried using "System.IO.FileSystem(4.0.0.0)" but the Root Class is showing neither of the classes.
The same if I do in Visual Basic it works.
Does anyone of you are able to see the classes available in the "System.IO.FileSystem(4.0.0.0)"?
Best,
Akshay
Message 6 of 8
(2,209 Views)
Accepted by topic author aparab
For .NET Framework APIs, you generally need to specify mscorlib instead, as follows:
Message 7 of 8
(2,198 Views)
thanks dug
Message 8 of 8
(2,179 Views)
