NI TestStand
Save and load Global Variables
Hi all
I've got the following problem:
At the moment I'm working with a spectroscope. I have to extract some peaks, which are produced when the ligth is refracted by different materials. And I've got two references saved as global variables to compare with: one is a dark reference (without any light & materials) and one only with the light.
But when I'm restarting my system at the moment, I have to store both references again (because they're just saved within the vi's).
Is there a possibility to save this variables in a .txt or .xls-file, where they can be easily load from after restarting the program?
Thanks in Advance
Dave
(3,589 Views)
Is this a TestStand question or a LabVIEW one?
If is a LabVIEW, I would suggest you re-post to the LabVIEW forum
Regards
Ray Farmer
Message Edited by Ray Farmer on 07-12-2007 12:57 PM
Regards
Ray Farmer
(3,586 Views)
yeah, is a LabVIEW one... Sorry Smiley Surprised
(3,582 Views)
To programatically force a save of station globals in Teststand you need to use the Active X adapter, and the Tesstand automation server (selected when you specify the active X call).
(Just incase anyone, like me, spent three hundred years looking through the tesstand forum trying to work out how to do this simple thing).
Because the "Teststand API" methods are often referred to , but the secret of accessing them is closely guarded and hidden.
(3,523 Views)
