NI TestStand
Save data directly into an Access Databes with the Database Options configuration in TestStand 3.1
  I have written a dummy sequence to save data into an Access Database. I've just created the database and under Configuration->Database Options, I have created a new Schema. In the Statements for this Schema I've created one corresponding to one of ny tables in the database and in the Column/Parameters tab the corresponding fields for this table. When I run the sequence, I get an error               "-2146825037; User-defined error code." in Step 'Log Results to Database' of sequence 'Log To Database' in 'Database.seq'. I attach the screens of the configuration, database and sequence. Some idea? Thanks in advance!!
Message 1 of 1
(3,634 Views)
