NI TestStand
Saving view settings in TestStand
Hi
We are a few TestStand developers all using the same physical test station at times. We each have a user set up on the system, but it annoys me a bit that every time I use the system somebody has changed the "views" away from the way I prefer them to be (it probably annoys the other guys as well that I change them back 😉 )
Is it possible, somehow, to save the view setup of the environment, i.e. I like to have my steps in the middle on the top, my variables list on the right and my sequence list on the left etc.?
Martin
(1,388 Views)
If you use .tsenv then include LocalAppData (see this). Check also this (User-Specific Application Data section). Keep in mind that you have multiple configuration files in TestStand and sometimes you need to use more than one to set up what you like.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(1,365 Views)
