NI TestStand
Scope of File Globals
While using file globals to pass data to another sequence, is it necessary that called sequence has to be a subsequence of the calling sequence. In other words, if I call a sequence file that is not a subsequence within my calling sequence, will the called sequence be able to access the file globals of the calling sequence?
(3,407 Views)
Accepted by topic author Flamboyant
FileGlobals are in scope to any sequence within the same Sequence File.
eg
Sequnce A and Sequence B contained in SequenceFile SF1 which has a FileGlobals FG will be in scope to both sequences.
whereas
Sequence A contained in SequenceFile SF1 its' FileGlobals will not be in scope to Sequence B contained in SequenceFile SF2.
Hope this is clear
Regards
Ray Farmer
(3,405 Views)
And also FileGlobals are "Execution local", i.e. if you are calling the same sequence from two different executions, e.g. two TestSockets in a parallel model, then you will have two distinct copies of the FileGlobals.
Regards
Peter
(3,399 Views)
Unless you set the property to Shared FileGlobals.
Regards
Ray Farmer
(3,378 Views)
Yes, right, forgot that.
Peter
(3,376 Views)
