NI TestStand
Scrollable list of subpanels in labview
I am making a program that sweeps software parameters of a DUT and logs measurements from various instruments while doing so.
To make this program more flexible, I want the user to be able to configure an arbitrary set of instruments (including multiple of the same kind) to log measurements from. Each instrument has different configuration parameters.
What i need is a dynamic UI, where I can add (and remove) Instruments and have a different configuration UI for each instrument. I made a little sketch of what I have in mind: UI proposal
What I tried so far is to have an Array of a Cluster with a Subpanel in it, but all the Subpanels in the Array show the same VI.
(2,068 Views)
Try posting this on the LabVIEW board!
Regards
Ray Farmer
(2,049 Views)
