NI TestStand
Search for file names with Engine.SearchFiles?
I posted my comment to a solved thread: http://forums.ni.com/t5/NI-TestStand/searchfiles/td-p/2364238/page/2
and I haven't got a solution. So I post it now in a new thread.
Is it possible to search for substring in a file name useing the Engine.SearchFiles method? I know, that there is a SearchOptions_RegExpr, but I could not figure out, how to search for file names. I can find files, which contain particular expressions, variables etc. but not file names.
So, is it anyhow possible?
(3,887 Views)
Do you mean that you want file files with a particular name, or that you want to find particular file names used within a file? Those are two very different things. If you just want to find files with a particular name why not just use Windows file explorer?
-Doug
(3,881 Views)
Hi Doug,
I just want to find particular file names. But I want to do it programmatically, so I can't use the windows explorer. Or is there any trick to use that without user interaction???
Madottati
(3,878 Views)
Accepted by topic author Madottati
SearchFiles is only for searching within files. Take a look at the FindFiles sequence in:
<TestStand>\Components\Tools\ForEach.seq
This sequence searches for all files under a directory tree using direct calls to the WIN32 APIs. You could probably just call this sequence directly to do what you are asking.
-Doug
(3,871 Views)
