NI TestStand
Searching teststand variables
I have a variable call within my model, and that particular variable is not defined: Parameters.TestSocket.MainSequenceResults.Status
In this step, it is reading the value, so the value must have been written somewhere previous to this step.
I am trying to find out where - is there a way to search the sequence file for all the places where this variable is being used??
Thanks for any tips.
(3,813 Views)
To expand on my problem, I am using a model in TS 2010 upgraded from 4.1. LV was upgraded from 8.6 to 2011.
I have finally been able to run my test sequence all the way through, with some expected issues, but once it completes, the test socket window just blinks!
Then I need to Ctrl+Alt+Delete to kill it...
I traced the spot in the model where I think it may be hanging up to where this variable call is...but I don't think this is my problem.
Suggestions????
I am using a modified Parallel model.
(3,811 Views)
Open the sequence and do CTRL+F
(3,798 Views)
