NI TestStand
Security for Users.ini File
Hi All,
I've noticed that the security set for the User Management File (Users.ini) is absurd as when the users.ini file is deleted, the teststsand creates a new Users.ini file with a reset administrator user. And it was noticed that the newly created cfg file contains the administrator user with no password is created. I has a doubt.
1. Can the Users.ini file can be secured using Teststand itself, which I meant that can we give some unique password to the newly created administrator user as login apart from blank password.
I opt to secure the file using windows credentials. but a help to set a password for default user will be appreciated.
A BIG THANKS IN ADVANCE
Message 1 of 1
(1,563 Views)
