NI TestStand
See more than one Execution in User Interface
I have tester running in more than one Socket (normally 3), but in User Interface, operator can see the status or Execution in one a time, if he need to see a different one, they need to click other.
It's any way to see Three windos or Execution at the same time?
Thank you
(4,455 Views)
Luis,
You might be interested in the Multi-Window UI example we have in this whitepaper. There is also a .NET version of the example.
Hope this helps, and let us know if you have any further questions!
(4,444 Views)
souns good,
but it's cpmplicated to train new operators, and this will be used in some testers, if we cahnge the standars, we going to have some problems.
thanks
(4,413 Views)
