NI TestStand
Send UI meassages from teststand sequence to Simple CVI Operator Interface with Asynchronous Timer
Is it possible and how is it possible to send UI meassages from a teststand sequence to the Simple CVI Operator Interface with Asynchronous Timer which could be downloaded from NI Hompage. I use this problems because it is more stable than the standard OIs
regards samuel
Message 1 of 1
(3,169 Views)
