NI TestStand
Send an Email via teststand
I would like to send an Email with ActiveX Step Test in the sequence TS. Is it possible? what is it the method?
David
Message 1 of 10
(4,945 Views)
Hi Dav, do you really need TS/ActiveX to do so? Since I'm using LV anyway, I used the VIs supplied. Regards Oli
Message 2 of 10
(4,940 Views)
Thanks you, but i don't have LV and VI. I want to use TS with ActiveX
David
Message 3 of 10
(4,937 Views)
There is no built-in method in TestStand to send an email.  However, you can use the ActiveX/COM Adapter to call a code module that sends an email.  You may be able to find an existing component to do this, or can write one in a supported language.
Allen P.
NI
Message 4 of 10
(4,913 Views)
Is there any way to send email from Teststand for File Global values ?
Message 5 of 10
(3,779 Views)
I did not really understand your question....
You can format your File Globals into a strings. Assembling those strings in a large one, you can send this as an email
Message 6 of 10
(3,775 Views)
I need to email a string from Teststand which is stored in FileGlobals.
How can I do it?
Message 7 of 10
(3,769 Views)
For sending an email from TestStand you need an external code module (see above)
Message 8 of 10
(3,760 Views)
Thanks for reply.
I've another question:
My Teststand will launch a VI when it is executed. If Front panel of that VI was minimized or Closed, then Test stand must pause its execution. I like to have a Customize option [probably in Teststand toolbar] which should again relaunch VI execution from first. Is it possible in Teststand?
Thanks in advance.
Message 9 of 10
(3,756 Views)
Please search the forum first. I you can't find what you're looking for,open a new thread decsribing the use case and requirements more precisely, so you can be helped.
Message 10 of 10
(3,751 Views)
