NI TestStand
Sending AT commands using ExtraPUTTY to test cellular module.
I am using ExtraPutty for SSH communication with the DUT. In the test sequence i am sending AT commands in the Command parameter. But since the AT commands contains both value and alphabets(for eg."ql_cmd at 'AT+QRFTESTNR5G="rx",2,41,3,499200,0,-500,0'") wondering how to handle this in Testsequence without any error.
Herewith I am attaching the Screenshot for the reference.
Thanks and regards,
Mahesh.
(1,287 Views)
You need to use escape sequence to use special characters in a string
Santhosh
Soliton Technologies
(1,266 Views)
Hi Santhosh,
Thank you for the prompt response. It worked.
-Mahesh
(1,253 Views)
