NI TestStand
Sending Strings from PreBatch to PreUUT?
Hello everyone,
I am currently improving our test reports and I am working on adding the feature for users to add test notes before the execution of a test.
I have added this feature into the PreBatch subsequence because we use this to call a VI that we use to get the serial numbers.
Because I am adding the test notes to the UUT report header I have overriden the PreUUT Process Model callback to add the additional data and to set the include flag.
I have an issue however where the Test Notes string information doesn't seem to be getting copied and is instead showing up as  ' " ' .
Within the code module that we use to get the serial numbers and the test notes I output the String into a file global that I then include into my report under the Test Notes header.
Any ideas on why the string isn't showing and I only get this ' " ' ?
(2,322 Views)
Accepted by topic author Conor.
I figured it out.
Both the PreBatch and the PreUUT can see the ModelData property.
With a lot of help from a colleague I implemented the following code.
PreBatch Code
Statement (Add TestNotes Property)
Expression = Parameters.ModelData.BatchUUT.AdditionalData.SetValString("TestNotes",1,Locals.TestNotes)
PreUUT Code
If (PropertyExists("Parameters.ModelData.BatchUUT.AddiitonalData.TestNotes"))
       Statement (Populate Header)
          Expression = Parameters.UUT.AdditionalData.SetValString("TestNotes",PropOption_InsertIfMissing,Parameters.ModelData.GetValString("BatchUUT.AdditionalData.TestNotes",PropOption_NoOptions))
Statement (Include within Report)
Expression = Parameters.UUT.AdditionalData.SetFlags("",0,PropFlags_IncludeInReport)
I hope this helps whoever else comes across this problem 🙂
(2,307 Views)
