NI TestStand
Seq File Post Step Runtime Error and Failure
I am using  SequenceFilePostStepRuntimeError   &    SequenceFilePostStepFailure
in my seq file to handle  both.
the issue at hand is that,  once there is error the  execution runs to  runtime-error (SequenceFilePostStepRuntimeError) thats fine  then again i run my  Test-Step & error is generated  & it  again jumps to   runtime-error { Test-Step is a Pass/Failtest}
but after that it jumps to SequenceFilePostStepFailure. I want to avoid this.    can I reset the flag which says that no PostStepFailure ?.
    In my Runtime-error step I also change the "Parameters.Step.Result.Status"  to display my custom  status .
(5,399 Views)
Do i understand this sentence correctly if a state:
In your SequenceFilePostStepError callback, you change the status of the step calling into that callback because of a Runtime Error (Status: "Error") to the status "Failed"?
If so, it is expected behavior, no, it even is "works as intended".
You can use the TS API to disable the PostStepFailure callback, but you cannot enable this callback in the same step. So it would require an additional step for enabling the Failure-callback again which seems to makes things more complicated compared to NOT setting the step' result to "Failed"....
Norbert
Norbert
Expert: Geometry
(5,395 Views)
Thanks Norbert,
You got it right.
I change the status  as "Error 5506  Motor Fault"  & not as   "Failed"
I know if the Status  is "failed"  it will call  the SequenceFilePostStepFailure  callback.
(5,392 Views)
