NI TestStand
SeqEdit does not close the sequence
I have encounter some strange behavious while working with the SeqEdit.  I'm not sure if it was like that from the beginning.
When I close my sequence (File-->close, or CTR+W), the sequence disappear from the SeqEdit screen but it is not unloaded.  I know that because I put a breakpoin in my SequenceUnload sequence and it doesn't go there.  Also, when I open the same sequence again, it appears immediately without going through the SequencLoad sequence.
If I do the same thing with the Operator interface..is behaves differently.  The sequence went through the SequenceUnload and closed properly.
Why is that?  Is it a matter of some option to set?
Rafi
(3,520 Views)
Hi Rafi,
Just a few questions:
a) Does it occur after you have executed a sequence, ie open sequence file, run sequence (with or without process model) and close sequence file.
b) Does it occur after you just open and close sequence file.
c) Do you have any parallel executions running?
d) Do you store any references to executions or sequence files either in StationGlobals or code modules.
e) Are you using the default operator interface?
f) What are you doing in the SequenceFileLoad?
What version of TestStand are you using.
Regards
Ray Farmer
Regards
Ray Farmer
(3,522 Views)
Hi Ray and thanks for answering
Here are the answers to your questions:
     YES.  But in only happens after the first CVI step I'm running.
        NO.  I do run CVI steps in the FileSequenceLoad but the functions are in a different dll than the one I use int he main sequence.
      NO
        I don't know exactly what you mean.   I open a panel in the SequenceFileLoad and store its handle in the stationGlobas.  I also open GPIB instruments and store their handles.  Later, I use them in the MainSequence
           It only happens with the sequenceEditor.  It does not happen with the operator interface.
    Initialize GPIB instruments, start a panel
     3.5
Rafi
(3,487 Views)
Do you actually perform the QuitUserInterface() when you exit the panel?
Regards
Ray Farmer
Regards
Ray Farmer
(3,482 Views)
Hi Ray and thanks for helping,
I was able to solve the problem.
I found out that I did not clear objects used for Termination Monitoring.  Once I added the clear resources, everything works fine.
How is that relates to my problem?
Rafi
(3,464 Views)
