NI TestStand
Sequence Analyzer - File Specified by Expression:
In my 2014 seq i get the below information 184 times, one from each place I call python.exe with a .py script as parameter.
The sequence works perfectly fine, and the path to python.exe in StationGlobals.propertyLoaderCommon.pythonPath is in fact valid.
What does the "Description" mean ?
How can I manually add the "files expressions reference" ?
the sequence analyzer is very slow, I don't know if this could be the reason !
(1,513 Views)
Hi NikolajEgeskovOstergaard,
I think it is saying that the analysis tool cannot evaluate expressions (so will not be able to pull in any files referenced by expression into the analysis) so if you want files referenced by expressions to be included in the analysis then you need to add those files into the analysis manually.
Hope this helps
Steve
(1,487 Views)
