NI TestStand
Sequence Analyzer crashing TestStand
Currently working with TS/LV 2022 versions.   TestStand LabVIEW adapter set to LabVIEW Run-Time Engine " Auto detect using VI version."   Running sequence analyzer to help debug this system in preparation for deployment.  Sequence Analyzer begins to run, identifies a few sequence step errors/warnings, etc,(nothing out of the ordinary) then TestStand just shuts down and closes before Sequence Analyzer completes.  No error log I can find anywhere.  No TestStand Errors displayed on the screen.  The TestStand Application just closes.
If I set the LabVIEW adapter to "LabVIEW Development System"  everything seems to work fine.  Revert to Run-Time adapter and it crashes every time I run Sequence Analyzer.
Any thoughts or suggestions would be appreciated.
Message 1 of 1
(499 Views)
