NI TestStand
Sequence Editor Screen Resolution
I've just opened TestStand 14 on my new development laptop which has a native resolution of 3840 x 2160 and Test Stand display is really poorly sized - My main issue is that all the editor buttons are tiny (see attached screenshot.
I've tried changing my display resolution to 1920 x 1080 - no improvment.
Has anyone come across this and found a way around it?
Martin
(5,348 Views)
When you launch the sequence editor for the first time or when you reset the sequence editor configuration, the layout of the panes defaults to the Small Screen Example configuration or the Large Screen Example configuration, depending on the screen resolution.
TestStand considers screens with a resolution of 1280 × 1024 or greater as large.
Select Configure»Sequence Editor Options to launch the Sequence Editor Options dialog box and select a configuration.
On the UI Configuration tab, select an example configuration in the Saved Configurations control and click the Load Selected button.
Click OK to close the Sequence Editor Options dialog box.
"Getting Started with TestStand" chp2 2-2
(5,338 Views)
