NI TestStand
Sequence Editor or TestExec
Ni
I want to add some popups that will be only visible when the sequence is run from the Editor.
How can check if my sequence is being run from the Sequence Editor or from a TestExec.
(1,113 Views)
(1,091 Views)
The link shared from Jiggax mentions about "is editor" but its opening a different sheet.
In you msg popup pre condition add this : RunState.IsEditor
It will be true for editor and false for other UI.
(1,068 Views)
