NI TestStand
Sequence File Hierarchy Sequence Name Resize
Is there a way to resize the sequence name in the Sequence File Hierarchy Call Graph? I have a need to make the sequence names long and it does not fit in the file hierarchy.
Thanks.
(4,388 Views)
There is not a way.  The objects that hold the sequence names are a default size.  The best way to be able to view the whole name is just to scroll over top of the object.
Jesse S.
(4,343 Views)
