NI TestStand
Sequence File Translator in .NET
Hi All,
I've developed a sequence file translator in C# (.NET).
But TS can only call LV, CVI or C DLL for translator.
So I had to develop a C DLL wrapper which call my .NET translator.
I don't understand why TS can't directly call a .NET assembly.
In TS2019, it's the same thing.
It would be good to add this feature in a future release or update.
(2,860 Views)
Hi all,
I migrate my development on TS2022 and I see that there is not translator in .NET management.
I quite surprise that this plugin feature doesn't support .NET assembly.
All others plugin system manage that (report, property loader, ...)
(1,328 Views)
I have just stumbled over the concept of the translator some weeks ago.... and find it very useful!
since the documentation is also very.... limited, I suppose NI keeps this as a legacy interface and won't update it if there is no architectural or security related reason to do so
I sincerly hope, it doesn't become deprecated eventually...
(1,323 Views)
Thanks for your feedback. We currently have no plans to deprecate the sequence file translator.
(1,285 Views)
@maxmont wrote:
Hi All,
Do you happen to have a documentation about when thos callbacks are called? And their parameters?
I was not able to figure this put completely
Cheers
Oli
(1,269 Views)
