NI TestStand
Sequence Loaded event?
I'm working on the UI of TestStand. I would like to know when my sequence is loaded. Is there any Sequence loaded event?
(When SequenceFileOpened or DisplaySequenceFile are send, the sequence is not loaded...)
Julien
(3,510 Views)
Julien,
what do you understand when saying "is loaded"? If the sequence itself is in memory or if all modules are loaded?
The "SequenceFileLoad" Callback is called when the sequence file is loaded into memory, so no modules are loaded here....
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,506 Views)
Hi Norbert,
Sorry for the confusion. When I talk about sequence load, it's when the SequenceLoadCallback was executed. Is there any way to know through the UI ActiveX that this callback was run?
thx for your help,
Julien
(3,499 Views)
Julien,
nope, but you can inform your UI using an UI Message as last step of the sequence file load callback......
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,492 Views)
Thanks for the helps, Norbert.
I will try to find another way.
regards,
Julien
(3,488 Views)
