NI TestStand
Sequence Name preceded by a string in square brackets
I'm trying to understand a TestStand sequence, and when I look in the Sequences pane in the TestStand Editor, some sequence names have this format:
[aString1] ASequenceName1
[aString1] ASequenceName2
[aString1] ASequenceName3
PreUUT
PostUUT
[anotherString1] ASequenceName4
Do you know what the square brackets part is about?
Thank you,
Rollin
(583 Views)
Would you mind posting a screenshot?
Guess you are referring to some own code you are working on?
(562 Views)
After I posted my question, I was told the following:
  • The preceding name in square brackets is the name of a custom callback in a custom TestStand model we have.
(555 Views)
