NI TestStand
Sequence & SubSequence Results
Hi All,
I'm working ins TestStand 2013 in a Master Sequence that calls multiple subsequences.
After execution, the Report is breaking the Results in SubSequence PASSED/FAIL and SubSequence Items PASSED/FAILED resulting this in duplicated Fail elements in the ResultList
How can I merge or replace the Subsequence Top Result with the SubsequenceItems Results?
Example:
Begin Sequence: MainSequence
(C:\Users\x0213417\Desktop\STATUS Name Embbeding.seq)
5.1 Measure 5V
Status: Passed
(C:\zDevelopment\USB PD\TestStand Code\Subsequences\MEAS_VBUS.seq)
5.1_Measure 5V
Status: Passed
Measurement: 5.088935
Units: V
Limits:
   Low: 3.500000
   High: 6.500000
Comparison Type: GELE (>= <=)
End Sequence: MainSequence
My goal is to merge the above results into a single table.
Any feedback will be really appreciated.
(4,381 Views)
Hello m_adriano,
I'm curious about the necessity that you want to resolve doing this, do you have any special necessity to that? May be we can cover your necessity by another way.
Regards.
David P.
David P.
www.ni.com/soporte
(4,341 Views)
