NI TestStand
Sequence call of a External Teststand file
Can I call a Teststand file stored in a folder then add it as a sequence file in already existing set of sequence files.
(2,085 Views)
I'm not sure I understand your question.  You want to call a TestStand sequence from a sequence file in a different location?  And then copy the sequence file to a new location?
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,039 Views)
By moving few  content of the sequence out of the already existing sequence  file -> external files. Right now there is the steps are inside the settings sequence.This content could be stored external in a sequence file. So that may be I can call this external sequence from the already existing sequence and maybe some more to combine several measurements. Can these external files loaded during runtime with a LabView GUI?
(2,006 Views)
