NI TestStand
Sequence downgrade from TS 4.0 to TS 3.5
I recently installed TS 4.0 instead of a 3.5 I had before. I still have another machine with TS 3.5. I would like to now if there is a way to use the sequence files I created on TS 4.0 on TS 3.5. For the moment when I try to open a TS 4.0 sequence file on TS 3.5 I get an error message. I know there is an update process from TS 3.5 files to TS 4.0 but is there a process for downgrading?
Thanks In advance,
Moshik
(3,483 Views)
You would have to use the SaveAs and select 3.5 version option from the types control.
Regards
Ray Farmer
Regards
Ray Farmer
(3,482 Views)
Thanks - It helped
(3,477 Views)
I have the some problem when I want to downgrade my sequence file from 3.5 to 3.1. If I use the "Save As" option for normal sequence file then it is ok. However when I use the "Save As" option to downgrade my Process Model it giving me "type error" when i want to use the process model.
I need to do the followings:
1. Save the PM as a 3.1 sequence file in TS3.5
2. Open the PM in TS3.1
3. Re-save it again in TS3.1
(3,334 Views)
This does not sound like expected behavior.  Do you know what type is causing the problems?  Can you post a copy of the sequence file after it has been saved for previous?  It may be possible you have an unintended type difference on either your 3.1 system or 3.5 system.
Allen P.
NI
(3,319 Views)
