NI TestStand
Sequence file load
Hi
I'm using Lv operator interface and i need to
aquire the runstate of the 'seqeunce file load' when
the 'main sequence file' is being loaded .
Note: I can aquire the runstate of the sequence file load
when i'm running it after the file is loaded-(GetStates->runState).
Asaf
(4,064 Views)
Asaf,
Are you making modification to the LV operator interface. If so, there is a VI called TestStand - Is Seq File Loaded.vi or you could check the front panel control Sequence File.
If its just that you are using the LV operator interface and are generating Sequences. You could use the override SequenceFileLoad. That executes as the name suggest.
Regards
Regards
Ray Farmer
(4,064 Views)
