NI TestStand
Sequence file version number
My top level sequence is very simple. It calls five sequences which sit in five separate sequence files.
I the header of my report I'd like to have my five sub-sequence files version numbers. How to pull them out from the main sequence and push the information back to the process model?
K.
(3,050 Views)
Consider the attached example.  Run MasterSeq.seq and look at the report.  You would need to have the same logic in the Post-Expression for each of your sequence calls.
NOTE: You need both files and Slave1 needs to be in a searchable directory.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,018 Views)
