NI TestStand
Sequence file
I am new to NI teststand so when I try to open It is coming in some XMl format which is not understandable.so how i can see the backend code.
(2,666 Views)
What are you viewing the sequence file in?
Sequence Files by default are an object format therefore you can not view these in a text editor.
regards
Ray
Regards
Ray Farmer
(2,633 Views)
