NI TestStand
Sequence run VERY slow with SeqEdit.exe
Hi, My application sequence began to work very very slow while running under SeqEditor
Looking in the Windows Task Manager, it shows 50% constantly!!
Even steps like 'Lable' takes a longs time to execute.
Under Operator Interface it works just fine.
I have loaded some example sequence files from TestSTand/Example directory and they run just fine.
It seems that the problem is only with this specific file.
I can not use the SeqEditor as it is....PLEASE HELP!!!
Rafi
(4,053 Views)
Rafi,
what about the defaul User Interfaces? Is the execution there as slow as in SeqEdit?
Can you post your SequenceFile(s) which show the behaviour?
Norbert
Norbert
Expert: Geometry
(4,050 Views)
Sequence run fine with Operating Interface (as I pointed out in the first message).
Attached is the sequence file.
Rafi
(4,036 Views)
HI,
Further investigation showed that if I change the sequence file name, the problem goes away.
Does that give any clue?
Rafi
(4,021 Views)
What version of TestStand are you using?  Are you using Watch Expressions?  If you delete the watch expressions when the problem is seen, does it go away?
Allen P.
NI
(4,014 Views)
Watch expressions can be a big factor as Allen suggested. Regular breakpoints do not have any overhead; however conditional breakpoints do, so check to see if you have any conditional breakpoints defined.
Scott Richardson
https://testeract.com
(3,977 Views)
