NI TestStand
SequenceFilePostStepRuntimeError not firing
This should be a pretty simple question. Is the SequenceFilePostStepRuntimeError callback supposed to fire on a Sequence step which calls a sequence from another SequenceFile? It appears that the parent sequence's callback is not executed but the child's is. I think that makes sense I just want to be sure I am looking at this properly.
(2,845 Views)
Accepted by topic author rdecarre11
Any engine callback that begins with SequenceFile will only apply to the sequence file within which it resides and the steps owned by that sequence file.  Unfortunately, it doesn't apply to the call chain.
I posted about it here a while back with more details: https://forums.ni.com/t5/NI-TestStand/Engine-Callbacks-Confusion-question/m-p/3194242#M49300
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,833 Views)
Solid post, thanks!
(2,796 Views)
