NI TestStand
SequentialModel - Model Plugin - Fail sequence in UUT Start ModelPlugin and run next UUT
What i'm tryin to achieve is pretty simple :
We are trying to use model plugins to allow our clients to enable or not the traceability of their products.
What I am thinking here is that our model plugins would verify that the UUT is ready to be tested in with our traceability system and if not, I would like to fail the sequence without executing the MainSequence but I want the loop to continue executing after displaying the FAILED Banner message window as it does from the MainSequence.
If I make a Post Action in PreUUT Model Plugin that calls the PostUUT sequence, It calls it and then comes back to where it was, executing the MainSequence like I don't want to.
The problem I am facing is that I can't seem to control those things from the model plugin (which is my goal) because the process model belongs to our client and I want to avoid modifying his things unless I'm obligated to...
I would like to figure out a way to do everything from my plugin so I can deploy as a whole my model plugin.
I would like to avoid having to change some things outside of the model plugin.
Is there any way to achieve my goal ?
(2,956 Views)
Accepted by topic author ebonneau9
Here is the outline of a work around. It is a bit hacky, but seems to work ok with the SequentialModel. I didn't test it with other models, so it might require adjustments to support all models.
(2,926 Views)
Hi ebonneau9,
As far as I understand you call the PostUUT, right? Instead of calling it use the Go-to-Step functionality of the Post Action.
Jose F.
(2,924 Views)
Actually, I hit PostUUT but the problem is that I already passed the MainSequence there.
I need to cancel the execution of the MainSequence if I feel it should not be executed in the Model Plugin UUT Start.
After, all it is needed is to report the display banner of a FAILED Sequence and go to the next UUT
Hope I help clear things out, I know it is an uncommon way of doing things but at this point it is much more about decoupling things from my client and our side.
(2,920 Views)
Testing that right away!
I think that you pointed out a really interesting line of code which cancel the execution of a step!
I test that and if it does the job, I will accept this as the answer.
Thank you so far 🙂
(2,919 Views)
