NI TestStand
Sequnces pauses on teststep failure
somehow i accidently switched a property so that now when i run a sequnce that teststep "pauses" at this step.
When i cklick on continue in the menue then everything continues.
Where  can i switch this behaviour back to normal that the squence runs everything without pause on a fail?
Thx
(3,545 Views)
The only switch I know of is the 'Stop at First Step'.
The only other place is maybe you have a conditional breakpoint on one of your watch properties. You can clear all these breakpoints and watch items from one of the TestStand Menu items.
Regards
Ray Farmer
Regards
Ray Farmer
(3,544 Views)
Hey OnlyOne,
Were you able to getting your sequence working again?  One other property that you could have changed would be the Post Action parameters (in Step Settings).  Ensure that your On Condition True and On Condition False are not set to Break.  See the below screen shot.  If you are still having trouble, would you mind posting your sequence file.  I look forward to hearing from you.
Message Edited by JettR on 01-29-2008 02:19 PM
Best Regards,
Software Engineer
Jett R
(3,483 Views)
Under Execute menu, there is "Break on Step Failure" , "Break on Sequence Failure" make sure those are unchecked as well. I had the same issue.
(2,232 Views)
