NI TestStand
Serial number does not appear in report file name
HI,
I'm using TS4.1.  I'm getting a report with the serial number.  However, the filename of the report does not include that serial number.
example:
UDT_Report[NO_UUT_SERIAL_NUM3][2 35 46 PM][9 15 2009]    (see attached file)
Any idea what happend or where to look
thanks
Rafi
Message 1 of 12
(4,879 Views)
Hi Rafi,
How are your report options set up?
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
Message 2 of 12
(4,869 Views)
I had this problem a while back.  If I remember right I had a currupt process model and reinstalled the file and the problem went away.  You may just want to try reinstalling TS.
Glenn Ellis
Message 3 of 12
(4,857 Views)
Hi Charlie,
I have checked the box "New UUT Report File for Each UUT" but it didn't help and I don't want to reinstall TS. Any idea what could it depends on?
Thanks in advance
Giang
Message 4 of 12
(4,372 Views)
Are you running Single Pass or Test UUT's?
If you are running Single Pass you will not get a Serial Number (unless you have modified the Process Model)
Regards
Ray Farmer
Message 5 of 12
(4,369 Views)
Hi Ray,
Thank you for your prompt answer. I ran Test UUTs and when the test was finished I got 2 report file but the SN didn't appear on the file. I have BatchModel and 2 UUTs, Teststand 3.5. Could it depends on the BatchModel has been changed? since I'm not the only one who work on the computer. If so what is the right settings for the BatchModel?
Best Regards,
Giang
Message 6 of 12
(4,366 Views)
Check that you haven't got 'Store UUT Report in Batch Report File' enabled in the ReportOptions.
Regards
Ray Farmer
Message 7 of 12
(4,357 Views)
Hi Ray,
No I haven't check the "Store UUT Report in Batch Report File". The only enable option is "New UUT Report File for Each UUT". Please see the attached picture. I think the settings in Report Options are right and the problem is somewhere else, have you any idea?
Best Regards,
Giang
Message 8 of 12
(4,355 Views)
Do you override the ReportOptions in your SequenceFile?
Regards
Ray Farmer
Message 9 of 12
(4,339 Views)
Hi Ray,
No, I don't know how to do it, I'm quite new to Teststand. Is it possible to do so somewhere in TS so the SN can appear on the file name?
Best Regards,
Giang
Message 10 of 12
(4,329 Views)
