01-22-2018 08:39 AM
Hi all,
I'm in the process of improving some TestStand architecture here. One of the items in particular that I'm working on is the manner by which we pass VISA sessions between parallel / batch sockets.
I understand there are myriad ways of doing this (okay, maybe a dozen or so), each with pros and cons.
I like the idea of the Session Manager because it decouples dependencies between various code modules. However, the Session Manager's been around for quite some time and there isn't much information on it.
Thanks as always,
Mr. Jim
01-22-2018
09:58 AM
- last edited on
11-05-2024
10:19 AM
by
Content Cleaner
Session manager is here to stay and will be supported for the foreseeable future. It's already supported for 64-bit TestStand.
The only major known issue that i'm aware of is that the Session Manager VI cannot obtain a reference to a TCP/IP device unless it is already defined in MAX. This was fixed in TestStand 2016 SP1.
I can't speak to specific use cases, but there are customers out there using this as part of their architecture.
Hope this helps!
Trent
01-22-2018 10:00 AM
Thanks WireWeaver - your input is much appreciated!
