NI TestStand
Set CfgLocation back to default
How do I get TestStand back to its default directory.  Apparently this setting is in the registry but I could not find it.  TestStand 2019 cannot open since I inadvertently pasted a User Manager File path into the TestStand Configuration Directory in the Preferences.  No write access to the directory.
Not found here -
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\TestStand\19.0\
or here -
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\National Instruments\TestStand\19.0
It should not be this easy to break TestStand, it cannot start. Throws an error to make a registry change to the CfgLocation.
(1,705 Views)
Agreed. Can you post the copy of the error you are getting?
Anand Jain
NI
(1,665 Views)
The directory settings cannot be changed, it is maintained by IT.  Only option is to fix TestStand 2019
(1,658 Views)
Look like I overlooked the registry key. The value are located here for the record -
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\TestStand\19.0     (64bit TestStand)
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\National Instruments\TestStand\19.0  (32bit TestStand)
(1,649 Views)
I am glad you figured it out.
Anand Jain
NI
(1,645 Views)
