10-22-2025 03:05 AM
Using the following expression in a statement Step:
RunState.SequenceFile.Data.FileGlobalDefaults.mynum = 7,
RunState.SequenceFile.ChangeCount++
I am able to change the default value of a FileGlobal variable during sequence execution so I can retain it by saving the sequence file afterwards.
I would like to do the same for Steps parameters.
In a custom StepType coded in LabVIEW I can set Step parameters with the TS API:
Is it possible to do the same with a Step pre or post expression?
For instance, when I set the following post-expression in a PopUp step:
ThisContext.AsPropertyObject.SetValString("step.TitleExpr",1,"\"MyTitle\""),
the parameter value changes at runtime, but when sequence ends the new value is not retained.
Thanks for reading
Raffaello
10-22-2025 10:50 AM
I assume that "TitleExpr" is a custom property that you added to a step type
When TestStand runs a sequence it creates a run-time copy of a sequence so that changes to steps and most of their step properties (built-in and custom) do NOT affect the edit-time copy of the sequence in the sequence file in memory. This allows a sequence to be run in multiple executions or threads without stomping on each other. The one exception to run-time copies of built-in step properties is "TS" property, which is shared between the edit-time copy and any run-time copies, so any changes to RunState.Step.TS will affect the file in memory. This is not copied to conserve memory. You can only access the edit-time copy of a step using the context and this type of lookup path:
"RunState.SequenceFile.Data.Seq["MainSequence"].Main["YourStepNameOrIndex"]..."
Here is a topic that lightly touches on what is copied at run-time: https://www.ni.com/docs/en-US/bundle/teststand/page/executions.html
Hope that helps.
