NI TestStand
Set TS variables from OpInterface
Hi I am customizing my Operator Interface. In runTime (during the test) I have the necessity to read & write some variables (station global).
I developed a VI in order to get and set all the variables using the "TS-Get/Set property value". The problem now is that I cannot get the correct "sequence context" to pass to my VI. I tried to get the "sequence context" into the sequence inserting an action into the sequence that save the "sequence context" into a LV global, but it doesn't work.
Is this the correct approach? Are there different APIs that allow me to access to the TS variables in run time?
Thanks a lot for your support.
(3,152 Views)
If you are reading and writing to the StationGlobals, use the Engine.Globals to get a reference to the StationGlobals and then use the PropertyObject to set / get the value. For the Lookup string you only need the variable name, you dont need to start it with "StationGlobals."
Hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
(3,151 Views)
Accepted by topic author logatto
Thanks, you are right. I forgot to mention in my post that I tried also this solution. But I faced the same problem. How do I get the TS.Engine? From the "ApplicationManager.GetEngine", this is what I was looking for.
(3,138 Views)
