Hi Dave,
You can modifiy the ReportOptions, if you have available, via the Override Callback Sequence ReportOptions.
The ReportOptions container is passed to this Sequence during the early execution of the process model sequence, before it calls MainSequence.
Therefore, if you include the ReportOptions Sequence in your sequence file, you will beable to make the change as Scott suggested.
Regards
Ray Farmer
Regards
Ray Farmer
