NI TestStand
Set the sequence file format programatically through LabView API
Hopefully this question is very easy to answer: I would like to save a binary sequence file as xml or  a xml sequence file as binary with the labview API.
Is there a way to access the file format property or is there a function which takes the format as parameter?
Thanks in advance
Michael
(2,397 Views)
Accepted by topic author mthimm
You can use the FileWritingFormat property:
https://zone.ni.com/reference/en-XX/help/370052AA-01/tsapiref/reftopics/propertyobjectfile_filewriti...
Hope this helps.  Let me know if you have any questions.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,318 Views)
Many thanks.
I didn't find this property since the sequence file hast to be converted to a PropertyObjectFile by the asPropertyObject method.
You helped me a lot.
Michael
(2,279 Views)
