NI TestStand
Set value of a variable in NI Teststand.
I tried to set the value (for ex :"Hello" ) into a local variable (datatype is string) using the F(x) expression step type in Teststand. When i try to display the variable using a message box, it shows empty.I tried the same for FileGlobal and StationGlobal too. It dint work.
Please help.
(3,581 Views)
Try this example
Regards
Ray Farmer
(3,577 Views)
What exactly does you expression look like?
It should look like this:
Locals.MyStringVar = "Hello"
-Doug
(3,566 Views)
