NI TestStand
SetArrayBounds() giving me a strange output
When I use SetArrayBounds(), the output is not consistent with what I am expecting, I'll try to give an example:
I have this random array of strings:
Locals.OfficeSupllies = { "Pen", "Paper","Stapler","Monitor","USB","Clips","Cables","Mouse","Keyboard"}.
Let's say I need to ridimension it to contain only the last 6 elements:
SetArrayBounds(Locals.OfficeSupllies ,"[3]","[8]"),
The above array of string becomes:
Locals.OfficeSupplies = {"Pen", "Paper","Stapler","Monitor","USB"} and it becomes an array of [3...8] so the first string ("Pen") has the index 3 and not 0.
Is this behavior normal? Shouldn't it be Locals.OfficeSupplies = {"Monitor","USB","Clips","Cables","Mouse","Keyboard"} and an array of [3...8]?
To apply what has been said above, these 2 lines can be used:
"Locals.OfficeSupllies = { "Pen", "Paper","Stapler","Monitor","USB","Clips","Cables","Mouse","Keyboard"},
SetArrayBounds(Locals.OfficeSupllies ,"[3]","[8]"),"
(522 Views)
SetArrayBounds(): "This function changes the bounds of an array. You can use this function to change the size and/or the number of dimensions of an array."
To do what you want to do, which is take a certain amount of elements and make that the array, you can just use this "Locals.OfficeSupplies = Locals.OfficeSupplies[3..8]"
(496 Views)
