NI TestStand
Setting HTML report font size
Our test generates an HTML report. Set Report Font is called with charset -1, wt -1, font Tahoma, the size was defaulted. I changed the size to 1 but see no difference in the printed report. What must I do? I need to get a few more lines on the page and this is the easiest ( I thought) way to do it.
thanks,
jvh
(3,281 Views)
Known issue, though not very pressing as it may be fixed in 2010 or 2011 or ....
Workaround:
http://zone.ni.com/devzone/cda/epd/p/id/2578
(3,264 Views)
