NI TestStand
Setting Local variable in Model out of main sequence
I want to write to sequentialmodel.Locals.BatchSerialNumber. From out of the main sequence I can use runstate.caller. ...
But I want to write to it from out a sequence called from the main sequence. (I did a sequence call to another sequence from main sequence). If I write from this sequence to runstate.caller, I write to the main sequence. But I want to write to Sequential.Locals.BatchSerialNumber.
(3,108 Views)
RunState.Root.Locals.BatchSerialNumber
This will work if you start the sequence using the appropriate execution entry point.
PH
(3,100 Views)
Are you talking about Locals.UUT.BatchSerialNumber?
During execution, you can get access to get and set this value by using RunState.Root.Locals.UUT.BatchSerialNumber
-Jack
(3,099 Views)
Yep..... I forgot the UUT... model is the root object.... got it!
(3,092 Views)
