NI TestStand
Setting Model in Deployment
I'm using the latest version of TestStand and have created plenty of test solutions and deployments in the past, using the sequential model.
But this time, I'm using the BATCH model, and I just can't figure out how to include this setting in the deployment.
I've tried the following:
  1. Include public folders option - does not work, as the testexec.ini including has the sequential model setting
  2. Include the <teststand>cfg/testexec.ini file in the workspace and deployment - does not work, get Active X error on deployment machine
Would appreciate any help/advice
(5,085 Views)
Accepted by topic author morngoose
This information is stored in :
C:\ProgramData\National Instruments\TestStand 2012\Cfg\TestExec.ini
Under
[config]
StationModelPath2 = "BatchModel.seq"
You can write a simple exe which will modify this ini file.
Add this to the custom command list of the deployment.( check custom command button in the deployment -->Installer options).
Or
YOu can make all your test sequence settings to use batch process model.
Edit menu --> sequence file properties-->Advanced tab -->model options-->require specific model.
Overwriting the testexec.ini file is not good as it may already have some settings which may be overwritten.
Editing it should work.
(5,074 Views)
EVEN MORE IMPORTANT! ensure in your Deployment Utility settings, within the Drivers and components settings in Additional components for Full Deployment to ensure the TestStand Runtime AND the Process Model runtime are selected! this burned me for 2 weeks.
(3,877 Views)
I know its old thread, but still.
As brett has written:
I had a similar problem: in tester there was visible only Run Sequence button. After checking the TestStand XXXX Process Models Runtime in the Drivers and Components of Installer options in TestStand Deployment Utility, I see all 3 buttons: Test Sequence, Test UUTs & Single Pass.
With kind regards
Michal
(2,390 Views)
