03-27-2008 04:12 PM
03-28-2008 10:00 AM
03-28-2008 10:44 AM
03-31-2008 01:15 PM - edited 03-31-2008 01:16 PM
03-31-2008 01:46 PM
Hi Jett,
Thanks for your reply. I see you have spent some time with performing step calls. Time to give some 5!
If I would use the engine callbacks (Nr.18 in table). I would set a precondition to filter only my user StepType.
But now i think misha can select from two solutions.
Greetings
Juergen
04-01-2008 04:34 AM
Jett, Jurgen,
Thanks for spending the time for my problem, but unfortunately I cannot use none of both proposed solutions. Both are actually not a solutions but workarounds. Using them will require to maually edit all client sequence files, which contain steps of this step type. Instead of this I would prefer to provide solution on substep code level and replace only substep DLL on all involved PCs. Can anyone explain how its works in standard NI Step Types (NI_MultipleNumericLimitTest's Post-Step, for example) ? I already asked this (Message 7).
thanks.misha
04-01-2008 05:59 AM
04-01-2008 11:36 AM
04-01-2008 12:21 PM
